S175 lifting full totes.
Discussion in 'Skid Steers' started by ZGrant231, Jan 14, 2021.
  1. ZGrant231
    ZGrant231 Well-Known Member
    Sep 11, 2017
    63
    Oregon
    With much searching and no definitive answer. I'm looking to have a set of pallet forks with my s175 to off/on load totes, I'm currently rigging and slinging them with an excavator but I'm about to pull the trigger on a set of forks.
    Does any one lift/move/stack full 275/300 gallon totes with pallet forks on a S175?
  2. phil314
    phil314 Senior Member
    Dec 28, 2014
    279
    Instigator of Choas
    Otsego, Mn
    275 gallons of water is 2290 lbs + 150 for the tote = ~2450 lbs total.
    That is going to be pushing the limit of a S175 (1750lbs rated).
    A lot of that weight will be out a ways in front of the machine.
    It might lift it, but the machine is going to be very tippy, even with counterweights.
    so moving the tote after you've picked it up will be hard.
    You might be able to get away with it if you only have to do it every once in a while.
    If you do it every day, you aren't going to be happy with the S175.
    An S250 would be much more up to the task.
    My S650 is rated at 2690 lift. I unloaded a Bridgeport mill with it (2500 lbs).
    It worked, but it wasn't what I'd call fun. Glad I only had to do it once.
    Tenwheeler likes this.
  3. Tenwheeler
    Tenwheeler Senior Member
    Dec 15, 2016
    814
    Georgia
    I have seen a similar cat with farm tractor suit case weights brackets on the back. Those are easy to remove. Another had a bracket low at the bottom. They pored a concrete block in it.
  4. Jonas302
    Jonas302 Senior Member
    Jan 4, 2015
    1,026
    mn
    Its a little small I can do it with my 555 new holland that has the same rated tipping load as your machine but with a vertical lift boom and extra weights its a far more stable machine its still bouncing the back tires I would never want to pick one off a 4 ft tall semi trailer
    On the other hand forks have so many uses that you need a set anyways
  5. JBrady
    JBrady Well-Known Member
    Jan 24, 2019
    184
    NE OK
    The problem I see is you might be able to lift the tote a few inches off the trailer, but as soon as you back up or try to lower to the ground, you are going to face plant.
    ZGrant231 likes this.
  6. Tenwheeler
    Dec 15, 2016
    814
    Georgia
    I have done similar things with round bale hay. It a bit disturbing when you become comfortable with your minimum rated machine and the next load is heavier. Having it tilted all the way back helps. Use direct mount forks not bucket extensions. Coming off a double stacked trailer and it is coming to the ground. In that case the skid steer can be driven forward and hold the load up. Then kind of drag it down the side with a little forward pressure. You will not have that option.
    Many inexperienced operators of skid steers and Moffets have been injured that way.
  7. 62oliver
    62oliver Well-Known Member
    Nov 25, 2016
    104
    NWO
    Driving on the front wheels is a way of life with small skid steers, you need to be comfortable with your machine and keep your wits about you. Bigger is better.
