turfblazer
- Joined
- Dec 20, 2015
- Messages
- 72
- Location
- niagara falls ny
- Occupation
- semi retired drainage ,site work , eq operator.
this huge pump is coming out of a la-1000 aircraft deicer ground service support truck. bean royal pump
it was driven by a ford 4 cylinder industrial gas motor.
it has perfectly clean oil in it and does rotate as it should when clutch is engaged .
vehicle had 900 hrs on working tach , which means this pump has way less actual pumping hrs on it !!!
im pretty positive this is medium pressure and huge volume.
could be used for a sewer jetter for large pipes washer cleaner ??? farm pto tractor ?
if you have any fair offers i.ll consider the fair ones. this is by far junk !!! ive seen these used for 3000, new over 8k .
1st fair offer its gone
spray end valve nozzle gun also available nozzle sprayed aircraft
tom 998 nine two one zero prefer text contact then a call.
