Acoals
I got the bearing installed. Cleaned out the housing with a wire brush on the end of a drill. I took @Nige 's advice and left the bearing in the freezer overnight. It went in without a ton of effort. I just greased the housing lightly and then tapped the bearing into place with a hammer and a piece of square tubing. I did notice what appears to be a hairline crack in the outer part of the bearing. Not sure if I tapped it too hard or what, but I'm leaving it like that for now.
Thanks everyone for your help. This site has become quite a valuable resource for me as I work on this machine.
Most of the ones I have put in wind up with that hairline crack in the outer bearing race. It wont affect the bearing once it is in. Those bearings on the rear of those machines are a terrible design if you ask me, and it seems Cat agreed, as the newer models have the straight through design that the front bearing has. You have to grease those chassis bearings every few hours in order to keep them alive, and even then, those rear bearings quit taking grease after awhile. Every one I have ever seen is loose.
