Rock in the way
673moto
NorCal
Slacker
Found this little guy right smack dab in the center of where a pool should be... thoughts on best way to remove?
NepeanGC
Ottawa, Ontario
#dirtherder
Get a bigger shovel? Get a breaker for the shovel you've got? Drill holes and use Dexpan? Manual labourers and pick axes? Get a crane and some chains and lift it out? Though that last one is probably the most expensive option
rinse it off, drain the water, build a fire around it, quench occasionally until it's in manageable pieces.
treemuncher
West TN
eatin' trees, poopin' chips
Rock drill, 1-1/2 bit and Dexpan or other brand of non-explosive blasting mix. I cut out a custom fire pit into 3' of Maine granite with this method. Works great!
Don't forget your dust mask, safety glasses and ear plugs for this stuff.
673moto
NorCal
Slacker
Yep, leaning toward the Dexpan at this point.
Trouble is the thing just keeps going down further I dig.
Water table is crazy high here too considering it’s a drought in NorCal!
suladas
I'd say it depends what the customer wants to do with it, do they want the thing gone or just out of the way? No sense doing anything but breaking it up as it sits if it's going to be hauled away, if just moving it and you have the room to get in, a bigger piece of iron would probably be the quickest to move it.
Spud_Monkey
Your six
Decommissioned
There is nothing that can't be resolved by the use of high explosives ;)
On side note my Cat 977K could of picked it up like a pebble and moved it.
