Doug580l
I am planning on replacing the injectors but need help. I read the service manual and it sounds easy but now that I am closer to doing it I have several questions.
1) Do I need to remove the turbo? I'm pretty sure that I'll need to remove the muffler and brackets but if I try to remove the turbo, it looks like the bolts will break. They might break for the muffler brackets too.
2) I can't find the tools that the book says to use. A CAS-1066A wrench and a CAS-2155 injector cleaning tool. What should I use instead? I've tried searching online for a similar looking wrench, but I don't know what it's called and can't find anything like it. I've looked at some injector bore cleaning kits, but none of them have the 7mm size that I need and they are brushes. The Case tool doesn't look like a brush.
3) How do I clean the port? I've watch several videos on youtube but they were different engines and the procedures were all over the place. From wire and nylon brushes to carb cleaner and a rag on a stick.
4) Anything special I should be careful of so that I don't cause any damage?
Obviously I don't know what I'm doing and would appreciate any help. I do have the engine off the machine so that makes it easier to get to.
Thanks,
Doug
Thanks,
Doug
