skroll
What years are the "zero advance kit" appropriate?
Just pulled the injection pump off a 1976 580C. Are rebuilding it, pilot bushing bad, leaking diesel into the engine oil. Timing was very strange, wasn't set at 8, r or even zero for that matter. Si someone either just plain set it wrong, or is one tooth off on the drive gear. Know this is old post, but am getting ready to order parts and fix. Engine serial number 2818835. Not a "pipe plug" for a port opening, but a stamped steel cover. Thin flywheel, with 8, 4 & DC on the flywheel. And you just try and get a screwdriver in there to turn the motor, ha!
Know it is an old posting, but new problem for us.
skk
Phil, the injection timing for all the Case diesels up to and including the early 580 C's was 8 btdc. The 207 when first introduced had starting issues and we updated many of the injection pumps to a 0 degree timing kit at start to get the fuel into the cylinder while the chamber heat was at its hottest, This was accomplished by changing the pistons on the bottom of the pump housing where the advance piston is located, This kit with the updated parts was sent to us dealers by Case Corp. If the injection point is not 8 BTDC then I have mistimed literally hundreds in my career with Case. I can see useing a dial indicator to verify true TDC if one suspects the pointer to be inaccurate but once it is determined that is ok, the point of injection should be 8 BTDC. Once running the transfer pump pressure pushes the advance piston and advances to the running timing. Mel.
skk
