removing hydraulic bolts under pump
Discussion in 'Excavators' started by TomWei, Jun 15, 2021.
Tags:
  1. TomWei
    TomWei Member
    Aug 27, 2018
    21
    12866
    im replacing mounts and cant get the last line off to lift this side of the engine?
    i did take the first 2 bolts off with impact wrench, but put them back when i couldnt get the third off. its a tight fit with pipe and 4th bolt is by hand
    picked up s wrench yesterday and sprayed down with wd40 and pb blaster
    what else can i do before calling someone with muscles? bad area for heat?
  2. 56wrench
    56wrench Senior Member
    Dec 4, 2016
    811
    alberta
    there is always a way. human hands put it together, so human hands can take it apart, although not always easy. get some kind of a wrench or socket/breaker bar on the bolt and use a pry bar up along side the wrench to help pry against the wrench. it may take some imagination or other creative wrench manipulation. in this case no magic snake oil will make any difference in my opinion. i wouldn't use heat unless the bolts have threadlocker on them. sometimes i will take a cheap chinese wrench and heat and bend it to allow a better angle in restricted access areas
  3. Nige
    Nige Senior Member
    18,398
    A word of caution looking at those photos. Be careful using when regular sockets and accessories such as u-joints with an impact wrench. They could fly apart on you.with bad consequences.
    kshansen and 56wrench like this.
  4. uffex
    uffex Senior Member
    Jan 23, 2012
    2,202
    Admin
    Lincoln UK
    Good day
  5. TomWei
    TomWei Member
    Aug 27, 2018
    21
    12866
    thanks all, tried everything. 5 seconds of heat and it came right out with a S wrench
    have crowfoot in cart for next time
    Tarhe Driver and 56wrench like this.
  6. mutti_wilson
    mutti_wilson Well-Known Member
    Jan 14, 2017
    139
    Washington
    I've come to realize that having an assortment of extensions and wobblys long with Crows feet and long breaker bars is vital for hydraulic work.
    56wrench and uffex like this.
