SCISSOR69
I'm trying to remount this pump on a Case 580CK after being rebuilt. The drive shaft that fits into the female slot inside the pump, is it possible to rotate the pump somehow so the drive shaft and slot align? Maybe pulling that timing access plate off? I put the pump on, it goes all the way on to the shaft, then I feel a slight resistance like I'm pushing on the weights? If I am not alligned correctly could I get it to go as far as 1/4" from mounting surface.? I don't want to force anything and mess up the pump. Any feedback is welcome.
