Tomorrow we are putting some milling down on a private drive, 16' wide with a good dense graded limestone base. The base has been there for several years except for one 200' section that failed due to poor subgrade. A couple of weeks ago we put another 6" of dense grade over that failed spot and last Friday we took the roller, water wagon and a T250 and scarified the surface, wet it down and packed it. (This is a private drive of a business partner of mine, we work on it when we have the time and
he has the money..
, hence the spans of time between work
So the question is "to water or not to water". Since even red fuel is $3.50 a gallon, that is out of the question.
I have a Cat 533E for compaction, so we are covered there. The millings were hauled in and stockpiled many months ago, good, clean millings from a US highway.
I have a water wagon at my disposal (Ok it's my hydroseeder, little sucker has all sorts of uses
). Should we grade it out and spray the surface, then compact it?
To add- we will be placing geo-fabric down prior to placing milling on the poor subgrade section.
