Stevenbrla
First post:
We have a store where we sell pallets of grass sod (about 2000 lbs each), often onto open trailers which have rails down the sides...
Of course the pallet needs to be pushed at least up to the trailer axles, and sometimes further if the customer wants more than one... so that's like anywhere from 4' to 10' (or more) onto the trailer. Of course some of these trailers have ramps on the rear that can't be removed... so that makes it even more challenging.
We've been doing our best using our Navigator forklift, with scissor forklift mast extension, and even with fork extensions, which helps some... pushing, using another pallet to push, etc.
I see our competition uses a Gradall "telescoping forklift"... right terminology?
We've got to come up with a solution, and if this is the best option, then we've got to do it. Suggestions?
Here's a few notes:
1. Our lot is relatively small, so the smaller the machine, the better.
2. Our lot is basically covered with 1/2" rock.
3. Estimate that we will load 4-10 pallets per day.
4. We plan to buy used.
5. We're in south Louisiana... cold is seldom an issue.
6. Machine will be stored outdoors.
7. Pallets weigh 1600-2500 pounds.
Open to any feedback you can offer... and most appreciative..
Here's a few notes:
