hey guys I had my engine rebuilt on my mm 30 misubishi this spring, from new crank up,pistons,rings,bearing, head redone,ect, after 50 hrs, after the rebuilt the engine still has a steady stream of blue smoke,so bad it over come you burns your eyes,i think new rings should be broken in by now,what to look for,to do a compression test do you pull out injectors? I rebuilt several gas engine in my life, did not want to try the diesel,guess I should have
