Rebuilding boom cylinder. 322C
fastline
OK
Hoping to get both some procedural data from SIS and/or possibly some opinions of approach on this one. I will be rebuilding one boom cylinder. I realize most would say "do both" but other one was done recent.
Historically I have always rebuilt my cylinders and custom machined tools to do so, but have never done one of these booms and I am trying to figure out if/how I want to approach it. I think on the last one I did, I unpinned the rod, then rolled the cylinder down and set barrel on cribbing. Then pulled rod. I can't recall how I held the rod eye to apply the massive piston nut torque though.
Opinions welcome!
fastline
OK
I thought a plugged in HEK serial. Or I can find and email the whole serial?
Jonas302
mn
I would pin it to the back of your dozer supported by v cut wood blocks then if no other heavy equipment around plug the lines so you can use the hoe to push the wrench
fastline
OK
Thank you very much! Now I guess I need to decide if I want to tackle this. I swear every time I do one, I say I am going to build a hydro bench....lol
Does anyone know the 'proper' way to hold the rod eye when applying the "holy jezuz' torque to the piston nut? In past yrs we have just repinned to the machine to hold it but I suspect that is not a real good way and could damage the bushing.
