earthscratcher
in my last shop i remember welding and grinding away, not 6 feet away was a rebuild torque converter and rotary manifold that needs worked on. i was like i need a area that i can work on and keep this stuff clean until install.
so the little rebuild/clean room is under way its 30 ft long and 8ft deep 8ft tall it will have its own heat and air mini split system. it will have a man door and a 8ft wide rollup door for the fork lift to bring stuff in.
i was thinking keep the area in front of roll up door open with some type of i beam trolly system to move stuff to work tables that would be left and right of door. what are those work tables called that turn heavier objects?? i need one of those.
any way how would you design a rebuild room in a 30ft by 8ft by 8ft tall space. ???
