Readying for the KW
Discussion in 'Trucks' started by DMiller, Oct 13, 2020.
  1. DMiller
    DMiller Senior Member
    Feb 22, 2010
    11,254
    Almost Retired
    WAG's are a good thing!
  2. kshansen
    kshansen Senior Member
    Mar 11, 2012
    9,593
    Central New York, USA
    I know it's easy to spend other peoples money, did it for 45 years at the quarry, but I would not even be tempted to reuse those springs.
    Just glad to see you found something that seems obvious as to the problem you had.
    Spud_Monkey and DMiller like this.
  3. DMiller
    Feb 22, 2010
    11,254
    Almost Retired
    Made a preliminary parts order thru the KW Dealer again. Parts guys do not know what to make of my orders, generally have numbers and alternate paths for components lined up, they do not have to do much footwork.
    Filter base one of three ways, Full assembly, Subgroup assembly with all the small parts but reuse head to engine block adaptor, and blank head with two poppets two springs. The eight rod bolts I had removed, several small pieces I was looking into and priced Cooler bundles as to Cat Price, WAY out of my ballpark so did a Net search by p/n, have 'New' one ordered thru a NY Dealer $535 Shipped or 1/3 the price of Cat New and $300 less than Reman.
    mks, 56wrench, Nige and 3 others like this.
  4. DMiller
    Feb 22, 2010
    11,254
    Almost Retired
    Filter head assembly arrived today, new relief valve Poppets and springs with Rod bolts yesterday.
    Old vs New
    When installed into housing were a good 1/16-1/8" taller than removed.
  5. Nige
    Nige Senior Member
    18,836
    We had a lot of trouble with wear in the oil pump relief/filter bypass valve seats (circled red) in the oil filter base assembly on C13 engines in 349D excavators, and of course the C13 is a derivative of the 3406. It got to the stage where we were replacing the complete assembly at engine midlife in order to maintain oil pressure.
    Labparamour, DMiller, bccat and 5 others like this.
  6. DMiller
    Feb 22, 2010
    11,254
    Almost Retired
    Wanted a loaded preassembled sub section for this one, Not in inventory but the bare bones housing was. Am satisfied. What I do not get is the housing is Aluminum, wear points will take a beating. Also Made In CHINA!!
    Labparamour likes this.
  7. Truck Shop
    Truck Shop Senior Member
    Dec 8, 2015
    7,484
    star gazer
    SE Washington St
    Yup-but it will take many hours.
    Labparamour and DMiller like this.
  8. Nige
    Nige Senior Member
    18,836
    We couldn’t understand that either.
  9. DMiller
    Feb 22, 2010
    11,254
    Almost Retired
    The valves are EGP I understand that but allowing a spring to drive that resilient material into a aluminum seat is stupid, would have been easy enough to add SS seats for the valve poppets to seat up to and not require replacement of the head in total every time seat damage occurred. Where it hangs and what it supports the entire assembly in cast steel would be a better choice regardless.
  10. John C.
    John C. Senior Member
    Jun 12, 2007
    9,991
    But it's made in China! That should be its own explanation.
    DMiller and Labparamour like this.
  11. DMiller
    Feb 22, 2010
    11,254
    Almost Retired
    May have to fire my parts cleaner as does not perform so well these days!!
    Ready for bundle as gets here.
  12. 56wrench
    56wrench Senior Member
    Dec 4, 2016
    905
    alberta
    Lots of stuff uses aluminum nowadays to save weight at the expense of durability. Good old cast iron was heavy but lasted a long time. Look how light engine blocks are now for the high hp they get out of them which leads to durability issues. ie torisional twisting and liner counterbore issues on some engines in high-torque applications. If the blocks were heavier and larger water jackets around the liners i feel we would have fewer problems and engines would last longer. Engines run hotter to decrease emissions which causes the entire cooling system to work harder as well as oil coolers, etc. There has to be high oil flow for max piston cooling and load carrying in the rotating assemblies. And now we're talking low viscosity engine oils. All this adds up. Plus, aluminum is cheaper and easier to use in manufacturing than cast iron. Just living in the modern world:(
  13. John C.
    Jun 12, 2007
    9,991
    Cheaper and easier is what they like in China!
  14. DMiller
    Feb 22, 2010
    11,254
    Almost Retired
    Air compressor back on
    P/s pump to block oring changed
    Reattaching all manner of stuff took apart figuring on pulling engine
    Next up bottom end rod bolts on 3&6
    Oil pump and structure
    Pan
    Pull drain plug flush off top deck of head.
    Meanwhile had to make a Orschelns store run found a bargain
    T4 rotella 15-40 $14 a gal in 2.4 gal jugs
    Bought all they had
  15. DMiller
    Feb 22, 2010
    11,254
    Almost Retired
    Rod bolts swapped and torqued, oil pump and piping with reinforcement tray back up, pan back on down to ONE bolt, managed to lose ONE spacer and had one thread pull in the R Rr corner to rear structure will have to coil.
    Intake boot Els to turbo on, harness reconnects in progress and coolant hoses all reattached save the connections at oil cooler
    No bundle as yet.
    Getting some small crap out of the way so done as cooler gets replaced. Block heater element is shorted, cord is trashed at element.
    Small parts order at KW in morning.
  16. DMiller
    Feb 22, 2010
    11,254
    Almost Retired
    Parts ordered be in Wed, cooler bundle arrived as did trans jack today.
    Is a CTP core likely from BesGuesistan or a little known Chinese iron peddler but appears correct sizes to install.
    Jack is a OTC, pricing was close enough for off brand names to warrant a name brand and no it is yet still boxed up. Tried to beg borrow or buy a used one, nothing even closely resembling usable and still wanted big coin. Sold a old ratchet style Many Moons ago and was glad the death trap left.
    This was bought in case needed remove the entire engine. Can utilize it more now than just that.
    And I have LONG Since graduated from do it rough and dangerous style, this is more sensible to me nowadays.
  17. DMiller
    Feb 22, 2010
    11,254
    Almost Retired
    Is a new block heater element in the left housing, all is tight just need to finish tyiying up loose ends.
    Truck Shop, Paul Council, JPV and 3 others like this.
  18. Spud_Monkey
    Spud_Monkey Senior Member
    Sep 15, 2018
    2,645
    Time to take a hot water pressure washer to that engine to compliment the new parts.
  19. DMiller
    Feb 22, 2010
    11,254
    Almost Retired
    Have to get it outside for that!! Do not have a Hotsy here so will end up taking to local car wash when drivable. LF Drive brake has been frozen Applied since arrived, once engine is up and viable then on to brakes. Have to pick my battles strategically currently.
    56wrench, Spud_Monkey, mks and 3 others like this.
  20. Truck Shop
    Dec 8, 2015
    7,484
    star gazer
    SE Washington St
    What did the sealing material look like for the cooling tubes in that oil cooler bundle? If it was soft and disintegrating it was bound to
    start leaking internally? Age really gets to those. Same as my trans jack-you will be glad you spent the money. Best jack there is. Plus
    way safer to use.
