Chass
- Joined
- Dec 6, 2013
- Messages
- 65
- Location
- Adelaide South Australian
- Occupation
- Owner small earthmoving & landscape business
Ok had to replace inner drive sprocket on my rc30 (Right hand side) could not remove drive sprocket assembly off drive shaft, so had to remove nose cone off drive motor 8 or so allen key bolts pressed off the sprockert assembly no prob i replaced the seals while I had the nose cone off. fitted it back to machine I wanted to check to see if would drive well no good left side no problem but know the right side which i replaced seals does not drive, I did drive it into the workshop so it all work fine apart from the broken inner drive sprocket. please help any ideas????:Banghead
