Weird thing came to my mind ceramic toilet bowl cost $100, ceramic tooth $1000.
Thank You JL,Melben, you seem to be mentally strong for 77. Good for you. My did retired yesterday at 83. He has been a barber for 62 years and is still sharp as well!
I hate Wisconsin engines with a burning passion.....Honcho, many years ago I had 3 front teeth knocked put by a Wisconsin engine crank ( they were a manufacturer of air cooleds here), I needed a tooth repair and it involved the bridge that was installed using anchor teeth on each end. They wanted $7000.00 ton replace the permanent bridge, I said not at 77 yrs of age are you putting that much money in my mouth. They finally filled the tooth in question a whole lot cheaper. $265 was the damages when it was all said and done.
Will not be fun, we will be thinking of you and hope all goes well!Joe-h. I wasn t on the throne, but today I got to see my dentist. A small piece of my mollar got broken, need to fill it.
Had a tooth extracted last year. It was beyond saving. The way my root system is, they had to put me under, and get it out Guy said it took him 40 min, biggest roots he had ever seen. Now I keep biting my tongue. They want to drill my jaw, put an anchor in, and put a new tooth on top. It was $360 to remove the old one, and they want $4000 for the new one. So I guess I'm going to have to learn not to bite my tongue.I used to have a tongue piercing and one day I managed to chomp down on the metal ball of it with my very back, top, right tooth. I went to the dentist and they basically said we can try to fill it or you can just leave it be and the sensitivity would decrease over time. I went with the latter route and it's been fine, though weird to have kind of a triangle shaped tooth back there. I only notice if I jam my tongue back there. 1000 bucks is expensive, sounds like the Russians have similar prices as Americans on this one.
Shop around! Huge range of prices for implants because it's big profits. I've heard anywhere from $500 in California to $6,000 in Indianapolis.and they want $4000 for the new one.
I knew a lass with one......still trying to wrap my head around aighead's tongue piercing
If I run across that I think I'll just head on home your a better man then meI had a lady friend that had a piercing in her belly button.
She used to hang a Pine Tree air freshener on it.
All I can say is OUCHDifferent times! It was, I think, a 21st birthday present. It was kind of cool and it stayed in until I broke that tooth, then I was done with it.
No muff too tough, we dive at fiveI had a lady friend that had a piercing in her belly button.
