That's it Dan.
As far as valves go, Ric at GardenTrucking.com can fix you up, if your not going to be pushing to much volume. Which, you may be to big on scale, because these valves are only a 3 mm port. But he has single up to 6 valve blocks.
I'm running a 2 valve, 174psi or 10bar, 350ml pump, and I would like a little more volume. Good luck.
