Deere Foreman
So I purchased a 2012 Case cx36b mini ex from a local contractor a couple of months ago. The machine runs and operates great... except for whatever reason this machine is stuck in the high range 2 speed. Which for most things works okay, but really limits you in your turning in tight areas. I took the machine to the dealer, and then to one other reputable shop after that to fix this issue. $5000 later and a bunch of useless new parts thrown at it, and it is still not fixed, no one can seem to figure it out. So my question... if I were to pull the high speed lines loose from each drive motor and cap them off, then plug the hole in the drive motor...would it put the machine back in low speed? Eliminating the 2nd speed, which is fine with me.
