Quick connect conversion
Discussion in 'Skid Steers' started by Ronfire, Sep 19, 2021.
  1. Ronfire
    Ronfire New Member
    Apr 3, 2021
    1
    CANADA
    I would like to add the hydraulic cylinder to the bob tach . Can I add on the cylinder and connect it to the hydraulic connections for attachments and run it that way?
  2. Aarons81
    Aarons81 Well-Known Member
    Jan 1, 2021
    112
    Central Ohio
    I don't see why not.
  3. Midnightmoon
    Midnightmoon Senior Member
    Nov 9, 2013
    414
    Ny
    You should check hyd pressure specs on bobtac before hooking to aux. Most are hyd release and spring locked that may cause an issue without the right hydraulic valving for the bobtac.
  4. CM1995
    CM1995 Super Moderator
    10,510
    Welcome to the Forums Ronfire!
    You need check the hydraulic pressure on the aux. Standard Bobtach hydraulics are much weaker pressure wise than the aux's. The aux. probably have the power to break the handles/pins.
