Hi's and lo's in pipe
Hi, Alan Mesmer.
Firstly, welcome to the forum.
I have found that having hi's and lo's in perforated flexible pipe is not altogether a bad thing. While it may not get rid of all the water immediately, it does leave small reserves there for when the ground dries out a little. It works on more or less the same principle as the 'S' bend in a flush toilet. In fact, one local council for whom I did some drainage work in several of their parks wanted uneven-bottomed trenches for this very reason. Trouble was, they wanted the irregularities to be more or less regular, which was a PITA for the poor digger operator - - - I was on backfill and clean-upon those jobs. He, He, He.
The councils were using 3" and 4" perforated flexible pipe but I'd reckon 2" would be adequate for this lawn job, unless it is a fairly large area, with perhaps a larger diameter for the main pick-up pipe to the outlet.
KMSEXC, hope this helps. I have parts of my lawn that have 8% - 12% fall on them and they don't drain quickly either, 'cos the grass holds the water within its mat to a surprising degree. Sub-surface drainage seems to me to be the way to go.
