Tinkerer
Like the title says - never again.
I had a bit** of a time getting the piston in the cylinder. Screwed the gland down and the piston was so tight I couldn't get the rod to move. I had to chain the barrel to the tractor frame and use my truck trailer hitch to pull the rod back out.
Two piece piston. The seals that are on the bottom of each stack are way out of spec. So bad that I could see a bulge on them while the piston was still tight on the rod. I found that the ID of them was quite bigger than the others. That allowed them to move off center and create a bulge.
A new kit from CNH is on order.
