I'd like to water my garden from a nearby river with a 2" pump. I want to keep the pump at the top of the bank, because the bank is very steep, 10 vertical feet . I don't have a foot valve for priming. I've got a 1.5" venturi which I'm pondering glueing to a two inch pump. I know the simplest and surest way would be to place the pump on a raft down low in the water and maybe that's the correct answer.
To access the water, I could build some steps into the bank.
I've also got a cheap chinese diaphragm pump that I could use for priming but it struggles lifting 10' as the plastic handle bends under the strain of the vacuum.
Will it work ? How much draft lift can I expect from a 1.5" venturi ?
