That's why I mentioned the single axle dolly. 17,000 on a single axle I believe in missouri, if you put the sliding fifth wheel ahead of the single axle I was thinking around 12 to 15 on the pintle and same on the axle. Say 30,000 total there would allow me to pull a 322 cat hoe with permit. I pull a 963 on a triple axle pintle now but that's all I want on it. 322 are around 55,000 I believe so you could balance it and the lowboy half on the front and half on the rear tandems. I don't work a real big area and it's mostly rural.
With the empty wt. of my truck at 22,000 if I had say 15,000 lb. pintle weight that would give me enough traction as it's not real hilly around hear. It's just a thought, I haven't bought the hoe yet but am dealing on it.
I have hauled my 63 and a load of gravel a few times grossing over 100,000. You just don't get in a hurry. This setup would put me at somewhere around the 90 to 95,000 lb. range which is doable with that many axles.
