Pt1663 a30c slipping in reverse 1st
Discussion in 'Other Earthmoving Equipment' started by rmllarue91, Nov 4, 2019.
  1. rmllarue91
    rmllarue91 Senior Member
    Apr 17, 2014
    443
    field technician
    northeast pa
    Hey hef got a Volvo trans with valve body out. But I'm not finding what I thought. By looking at flow chart it uses k2 ( clutch 2 ) and brake 5 both used in either reverse 2 or forward 1 and they are strong. So if I have the right info and interpreting info correctly the trans its self should be good.? Any thoughts welcome. Trans oil is used but overall clean no debris.
  2. sfrs4
    sfrs4 Well-Known Member
    Jul 22, 2013
    122
    parts admin
    Great Britian
    Just picked this from prosis, says neither K1 or K2 are used, but strangely it also says in another section that S8 is for reverse but its not shown on the picture?
    S8 Solenoid for reverse gear
    S8 applies and releases clutch K2. Application takes place when S8 is not energised. Solenoid S8 is energised (clutch 2 is released) in all forward gears apart from 6th gear. When 6th gear forward is engaged, clutches 1 and 2 are applied. This is achieved by energising S7, but not S8.
  3. rmllarue91
    Apr 17, 2014
    443
    field technician
    northeast pa
    I was thinking miss print based on other Volvo trans info I found I looked a b and d models all use k2 for reverse ?
  4. Mark250
    Mark250 Senior Member
    Aug 30, 2015
    883
    heavy equipment technician
    victoria,Australia
    Hi, K2 is used in reverse but the S8 solenoid is not active. K2 clutch engagement is via relay RV8 as shown below
  5. Mark250
    Aug 30, 2015
    883
    victoria,Australia
    have you checked trans pressures
