PT 240 transmission issue
icewater75074
Texas
Field Tech.VOLVO Equip.
Has anyone had a problem with the torque convertor not coming out after the retainer has been removed?
wildhorse trnr
Texas
Field Technician
The back of the torque convertor is geared and needs to be aligned to pull free. I usually use a puller threaded into the coupler holes on the convertor, slight tension then rotate slightly till it moves out about a 1/4" then more pressure and it should come free.
