Problem with moba.
IHateTack
SC
We recently purchased an RX400 with Moba , but every since we bought it we can't seem to get the computer to running correctly. We've tried zeroing out the sensors and nothing. What's odd is you can zero it out and it will be fine as far as 0 level is concerned but right when it goes to - it acts up. We have it set to 4.5 on both sides to get a 6 inch cut. Its off 1.5 on both sides. I was just wondering if anyone had some suggestions ....
griz
usa
equipment technician
IHatetack,
can you go into the controller and tell me if it is on pr.h for (proportional) ,then check and make sure its in
(inchs) and not centimeters, this is a starting point so we can fix it. if not we can do it over the phone ok.
GRIZ
Toegrinder
CO
Milling Foreman
Also check and see if your position factor is set correct
