Powered grease guns
unimog
Missouri
I use Schaeffer products myself, they are great. I use some redline products in other applications but for industrial use Schaeffer is about the best. I hear Cen-Pe-Co is good but Schaeffer is available locally for me.
biggixxerjim
New Jerz
I have switched to Salesrep's grease and have found it to be good. I was previously using a grease from Lubrication Engineers that was excellent. I tried Salesrep's grease and found it to be just as good but a cheaper.
KSSS, try spraying a heavy concentrate of simple green on the grease spots on your clothes before they go in the laundry. They will come out clean as new. Also, when wiping excess grease off the equipment, a rag wet with simple green cleans really well.
WD-40 will work WONDERS on any greasy stain.... saturate the area, scrub it down a little, throw it in the wash, and PRESTO!!!!:cool2
Countryboy
Georgia
Load Out Tech. / Heavy Equipment Operator / Locomo
Try rubbing Gojo into the stains. I've always had good luck with that. :yup
