4,000 watt portable generator w/ Honda engine. The engine runs fine. When it was last used in the spring, everything worked fine. Now, it won't put out electricity. Checked the breakers and they seem fine. What are some easy things to check?
They took the cover off the generator? and cleaned up the end of the armature? with an eraser? while it was running. You know, the spinny roundy thing that the brushes make contact with. Had gotten a bit oxidized and wasn't making good contact with the brushes. Sorry, it's been a long time.
