I have a Greenlee hydraulic pole tamper that I'd like to use with my SVL95-2s. Tamper has a 2000psi limit and 7 gpm.
I would run it at low idle but not sure if that will limit flow enough.
Of more concern is pressure, don't want to blow the seals on the tamper. Will a pressure relief valve work? If so, what type, and how would it be plumbed?
I'm guessing it has an open center hydraulic system but I don't know. Talked to Kubota but they were Not helpful.
Any suggestions will be appreciated.
