Weekend Update II:
So I added a a couple shims to the relief valve on the TC and the pressure was reading 78 PSI (third gear stall main brake engaged) - one thing of note, there were a couple shims already in the sleeve, as well as a washer ... Is there a max number of shims you should use? Anyway, I decided to test her out and made a couple passes and it heated up as usual ... I did notice that it stopped a bit quick after changing direction, so I went over to a hill and sure enough it wouldn't roll down it in neutral. I took off the floor plate and worked and cleaned all the linkages ... they seemed very good and free ... I was about to give up for the day and I took my little bar and tried to pry up on the main brake connector (don't know the exact term, but when you press on the main brake it engages on a plate. Well the plate went up a lot more than it ever did for me before ... I was likely too gently on it ... anyway it instantly started rolling in forward and reverse ... I pushed dirt for about half an hour and it didn't really even heat up to 100 deg C (90 deg F outside).... Could just a slight main brake friction cause such overheating? I did clean the linkages before, and it did roll pretty freely, but I can't remember if it rolled better or about the same... I guess my last couple questions would be..
1. Should I be worried about my lower lube pressures?
2. Should I be worried about the amount of shimming in the TC relief valve?
3. How can I make sure that the main break doesn't stick, can I get heavier springs?
