Pintle hitches
Discussion in 'Equipment Moving Questions' started by Willie B, Jun 5, 2016.
  1. Willie B
    Willie B Senior Member
    Jan 2, 2016
    3,375
    Electrician
    Mount Tabor VT
    This is a question closely aligned to another thread. Pintle hitches are rated by trailer weight. Mine is not labeled. My trailer is a 9 ton. I presume the ring on the front of the trailer is good for the rated capacity. I hope it was engineered to be adequate. The hitch came on the truck. There is no rating printed on it. I loan it occasionally to professional excavators who have been in the business since 1953. They are amused that I am concerned. They have towed 46000 with my truck, something I will NEVER do!
    I'm confident that the hitch can handle 23000, but worry about tongue weight. Last weekend we had a 9000 LB tractor as far forward as possible, with a 6000 behind it. Can the hitch be trusted with extra tongue weight, or is balance important? The rig handles best with lots of weight on the truck.
    Am I being a puss as my friends suggest, or are my concerns valid? I want to stay out of the evening news. My conscience won't handle killing a family.
    Willie
  2. fast_st
    fast_st Senior Member
    Dec 1, 2010
    1,356
    IT systems admin
    Mass
    Pintle hitches are usually rated by size, what size is the opening on yours? Most of the shank ones are 6-8 ton, I know there are different size rings and different size hooks.
  3. Shimmy1
    Shimmy1 Senior Member
    Aug 14, 2014
    3,334
    North Dakota
    Can u post a pic of the hook? When I was working with my dad, we had hooks that were rated for 60,000 lb. vertical load. They had 8 bolts. I would venture a guess that if your hook has at least 6 three-quarter inch bolts, it would be more than enough for anything you can put on the trailer. This is what we ran.
  4. lumberjack
    lumberjack Senior Member
    Dec 24, 2011
    1,046
    Columbus, MS
    Where are the other 2 bolts to make 8?
    That's basically the same as my pintle also, 6 bolts, rated for 30T I believe.
  5. Steve Frazier
    Steve Frazier Founder Staff Member
    Oct 30, 2003
    6,314
    LaGrangeville, N.Y.
    It would be best to post a pic of your hitch, I'm sure someone will recognize it. The most likely weak link will be how the hitch attaches to the plate. I think if you've confirmed they are grade 8 bolts you'd be safe. For what it's worth, although I'm sure it's happened at some point I've never seen a hitch pull from the plate.
  6. clintm
    clintm Senior Member
    Jul 7, 2013
    974
    charlotte nc
    it's not always going to break at the time you overload. it will stress it then break later. I have broken them on a pickup truck because I got it in a bind. I have seen the swivel military style pull the threads off the nut years ago on a pup trailer because it had no tongue weight and no spring on the tongue. I don't trust a pintle hitch with any thing over #30,000 gross trailer weight seen to many break or turn over.
  7. Shimmy1
    Aug 14, 2014
    3,334
    North Dakota
    I knew someone would comment. :cool: I'm not sure if they've changed the hooks or what, but I can take a pic sometime. My old man's have 8 bolts. It looks like they just trimmed off the top holes to make 6. After I've done a bit of searching, I may have been mistaken on the vertical load number, unless they are rated less than they used to be with 8 bolts.
  8. lumberjack
    Dec 24, 2011
    1,046
    Columbus, MS
    Hahaha!
    My mounting plate has 2 holes above where the pintle is mounted like it replaced an 8 hole version.
  9. Willie B
    Jan 2, 2016
    3,375
    Electrician
    Mount Tabor VT
    I need to learn to post pictures. When I try I download to computer, then spend an hour finding it in the computer. Then it won't post. Mine is four 3/4" grade 8 bolts, (fine thread) through 3/4" plate. The plate is in turn, heavily reinforced with channel. It has a professional look about it. It has held up OK thus far, but I'm concerned.
    Willie
  10. lantraxco
    lantraxco Senior Member
    Jan 1, 2009
    7,700
    Elsewhen
    Sometimes you just gotta learn to let go... :rolleyes:
  11. Truck Shop
    Truck Shop Senior Member
    9,954
    star gazer
    SE Washington St
  12. Willie B
    Jan 2, 2016
    3,375
    Electrician
    Mount Tabor VT
    Thank you. None of these looks like a match, but it gives a sense of the probable ranges it might be rated. I recruited some expert help to post a picture. It sure ain't easy!
    Thanks again!
    Willie
  13. Truck Shop
    9,954
    star gazer
    SE Washington St
    I believe that hitch falls in the 30,000 lb range. IMO
  14. Willie B
    Jan 2, 2016
    3,375
    Electrician
    Mount Tabor VT
    Thank you very much!
    Willie
  15. ben46a
    ben46a Senior Member
    Mar 11, 2007
    773
    Waverley NS/Fort Mac AB
    I'd agree... 15 ton buyers pintle is good for 6,000 lb vertical.
  16. Steve Frazier
    Oct 30, 2003
    6,314
    LaGrangeville, N.Y.
    I was going to say the same thing Truck Shop, looks just like the one on my truck.
  17. Willie B
    Jan 2, 2016
    3,375
    Electrician
    Mount Tabor VT
    Thanks guys. I'm a little less concerned now. Tongue weight is important, I was concerned about having too much. I think we'll beef up the tongue tool box lid some. With the front wheels of a Farmall M forward on the tongue, (the whole tractor weighs 4000 LBS.) The heavy tractor can sit where balance requires over the axles.
    Willie
  18. Steve Frazier
    Oct 30, 2003
    6,314
    LaGrangeville, N.Y.
    Just be sure your bolts are Grade 8, there are hash marks on the head that will identify them.
  19. Willie B
    Jan 2, 2016
    3,375
    Electrician
    Mount Tabor VT
    My son & I discussed that a year ago. I thought they were grade 8. Now I realize they are only grade 5. They at least, will be changed.
    Willie
