Trailer info
The trailer manufacturer is Pro-Trak in Wills Point, Texas.
www.protraktrailers.com
Yes, the deck was welded up wrong. The layout was for their standard
suspension system, not the optional Hutchinson which has a greater axle
spread center to center.
Spring deflection/axle movement - The Hutchinson 9700 system has radius rods from the forward spring seat to the axle mounting pad, the spring ends are sliding in the spring seats so when loaded axle position doesn't move and
the springs flatten out sliding into the seats which will bring the cross member closer to the tire.
On delivery I didn't have much time. After off loading from the top position
(3 more trailers underneath), I noticed the GVWR sticker/ppr work was incorrect, the emergency air hose did not reach truck glad hand and the brake lights didn't work. So, I was busy and didn't notice the cross member
problem 'til later. The mfg took care of the GVWR, sent us a longer hose,
and offered to pay our out of pocket expense to fix the light wiring.
Sent ProTrak a fax, e-mails and made several phone calls - we want a new
trailer built correctly or a full refund. We've had no response for a while now.
Has anyone had any experience with ProTrak Trailers?
