I was at the right place at the right time for a change and got a great deal on a barely used Marshall Tree Saw. It's an interesting piece of equipment and isn't something I was even in the market for. After using it for an hour or so to thin out a few pine trees here at the house the main short coming I see is there is not tree control to speak of. Sometimes you can pull the tree back after cut to have it fall away, but not if it starts to go where it wants before then. I plan on modifying the guard so it can be used to push the tree away from the machine so I can control the direction it falls. For me, I think it will get used most for cutting fence rows through the woods where you can cut a tree at a time and push it off into the woods.
Anyhow, it looks pretty sturdy and really should last through a lot of use since nothing moves fast but it is heavy, bulky and long. The size of the cylinders is nuts, never seen any so large. Great peice of equiptment I think if I can work out a way to get the trees to fall where I want them. The real plus over a sheer IMO is being able to cut the stumps flush or even below grade. Plenty of vids on youtube if you've never seen one.
