Spiva Const
- Joined
- Sep 28, 2016
- Messages
- 57
- Location
- Camino, CA
- Occupation
- Retired underground utility contractor
My 09 335 with a 6 speed Allison transmission won’t shift into gear. Parked the truck and it worked fine, a few days later went to drive it, pressed the brake pedal, pushed the drive button and nothing. When you turn the engine off and with the key on I can push the key pad and it displays the gear selected, then start the engine and nothing. My
truck only has 40,000 miles on it. I have checked the harnesses for rodent damage but doesn’t appear to be any. I checked all the fuses. Maybe I should swap relays? Any ideas would be appreciated.
