Check the blowby on a cold day, you'll see water vapor puffing which is expected, but you want to see if it blows a big puff in time with the engine, and also if it's blowing any oil mist out with the blowby gasses. comparing to another engine is the best way to judge blowby.
Probably time to pull the injectors, get them checked, test the compression. You could try playing with the timing, and check the fuel pressure. There's a screen inside the inlet on the injection pump, check that after you've checked the fuel pressure, filter.
