Pc360lc-10 final drive slop
Discussion in 'Excavators' started by steve waldner, Jul 25, 2021.
  1. steve waldner
    steve waldner Well-Known Member
    Jul 5, 2017
    197
    huron sd
    Tracks are brand new oem ,sprockets are brand new 20 hrs
  2. steve waldner
    Jul 5, 2017
    197
    huron sd
    All pin and bushings on boom -stick- bucket are brand new , oem .
  3. steve waldner
    Jul 5, 2017
    197
    huron sd
    Swing Bearing is brand new.
  4. Tones
    Tones Senior Member
    Mar 15, 2009
    2,379
    Ubique
    Try digging over the sprockets then let us know if it's still moving. It may be a very simple fix.
  5. Iworkondiggers
    Iworkondiggers Member
    Sep 1, 2021
    11
    Aus
    Doesn't appear to be much movement in the final drive, looks more chain to me, looks a bit loose too, should be 10-30mm of deflection from the front idler to first carrier roller.
    How tight are those cover bolts too by the way, as they retain the ring gear
    Tones and Kobelco ireland like this.
  6. Tones
    Tones Senior Member
    Mar 15, 2009
    2,379
    Ubique
    When you replaced the track chains did you check the tension springs and the bolts at go through them? If either are broken they will cause movement like that. an easy way of checking is to pull the dipper with the bucket in the ground and over the idlers and see if the idlers are retracting into the frame.
