Pc360-10 swing circle
Discussion in 'Excavators' started by steve waldner, Jul 25, 2021.
  1. steve waldner
    steve waldner Well-Known Member
    Jul 5, 2017
    197
    huron sd
    Had some slop in swing circle bearing , replaced it with a after market from con equip. Took out all the bolts from upper , took all hoses from swivel , plugged hoses , used boom to lift machine high enough for undercarriage to clear, took sun gear from planetary , pulled lower out from underneath , set up down on tracks till ready for reassemble , took all bolts out from lower , lifted swing circle , removed studs , cleaned all grease from center Donut , new center gasket , rebuilt swivel , put new back on and reverse order . Bolts are the hardest part .
    John C. and skyking1 like this.
  2. steve waldner
    Jul 5, 2017
    197
    huron sd
    Oem is 16k after market is under 10k and is very high quality . 10k hrs
    skyking1 likes this.
  3. steve waldner
    Jul 5, 2017
    197
    huron sd
    Very solid , brand name dyco.
    John C. likes this.
  4. Lagwagon
    Lagwagon Well-Known Member
    Jun 20, 2018
    87
    Did you have whipped cream with your chocolate mousse?
  5. John C.
    John C. Senior Member
    Jun 11, 2007
    11,740
    How many hours did you get out of the first bearing?
  6. skyking1
    skyking1 Senior Member
    3,931
    Thanks for posting that up OP, it is on my short list to do on my 9300 hour 120 John Deere.
  7. steve waldner
    Jul 5, 2017
    197
    huron sd
    10k
  8. steve waldner
    Jul 5, 2017
    197
    huron sd
    But seal was hanging out when I Baugh machine , and had it buried in dugouts a few times
  9. John C.
    Jun 11, 2007
    11,740
    They used to only last about 7K. It was also nice to see Komatsu finally put all the circle bolts going up so cab and fuel tank doesn't have to be removed.
    steve waldner and skyking1 like this.
