I'm not familiar with this machines problems, what I've been told is that it is low on power and Komatsu have been out to check it, finding a possible injector fault. I was given a box of new injectors and a workshop manual late on Friday to do the job Saturday morning. I don't think it had a starting issue.
Few months ago I worked on a Cat924g different machine totally different fuel system however the starting problem was the same would only start on either, hot or cold engine, long story short, they changed just about everything pump, injectors etc, they reckon it was some corrosion around the fuse box area, all was good for a few weeks then again won't start, knowing this when I had a look at it, first thing I done was pull out the fuse box and check, what I found was some of the wires had been chewed through by rats or what ever but had not broken the wires, repaired the chewed wires. Haven't had a problem since, starts every time. Only thing I can think of is moisture was tracking between the open wires causing the starting problem. Not sure if it will help but anything is possible.
