Pauly17
I'm having an issue with my left track on my excavator. If I go in full speed with both tracks, all works fine. If I back out 1/2 way with the left pedal to turn still good but when I go to push pedal back to full the machine will track slow. If I touch any control (hand or pedal) it will return to full speed. This only happens with the left pedal and no other controls. Everything works fine other than this issue. I replaced the Pilot controller under the cab with no luck. From my understanding, there is a pump for each track, but this seems to be like a solenoid is hanging up or something of that nature. Also reading there is a merge valve when I touch another control will cause the machine to equally divide the hydraulic power to all the controls including the tracks so when this happens everything goes back to normal and the tracks work correctly... Any help with this would be appreciated.
