PC-150LC-6 Travel Motor
Discussion in 'Excavators' started by 59muskeg, Apr 23, 2019.
  1. 59muskeg
    59muskeg Member
    Nov 14, 2016
    21
    Columbus MT
    please see the attached pic. This is a Komatsu PC 150LC-6. Hydraulic fluid leaking from the small torx screw or the large hex. Area circled in Red. Not a bad leak now but enough to leak down & out the cover. Any thoughts. Thank you,
  2. Tones
    Tones Senior Member
    Mar 15, 2009
    1,309
    land clearing contractor
    Ubique
    Under the hex head there is usually a O ring that is in a recess. It may be bad and a easy fix.
  3. John C.
    John C. Senior Member
    Jun 12, 2007
    7,744
    I'm not familiar with that particular travel motor. I suspect that might be part of the counterbalance with a big spring underneath that cap. Maybe someone has a parts book on the motor itself.
  4. uffex
    uffex Senior Member
    Jan 23, 2012
    1,614
    Admin
    Lincoln UK
    Good day
    I would endorse JC comments attached is an exploded view sorry the quality is not so good
    Kind regards
  5. 59muskeg
    59muskeg Member
    Nov 14, 2016
    21
    Columbus MT
    Are you meaning the large hex head ? Wish I had a parts breakdown and I would not have to bug you guys on strait forward items. If you are referring to the large hex head it sure is tight.
  6. Silveroddo
    Silveroddo Well-Known Member
    Jun 23, 2010
    238
    Northern MN
    I had the same issue with the same machine, and while the finer details are fuzzy I remember we corrected it with an o-ring, I think it was coming from the larger nut. Clean it up with parts cleaner, lift that side of the machine with the boom and have someone run the track while you watch for the leak, shouldn't take long to show up.
  7. 59muskeg
    59muskeg Member
    Nov 14, 2016
    21
    Columbus MT
    Thank you. I will have a closer look. I do know that nut is on some tight.
  8. Silveroddo
    Jun 23, 2010
    238
    Northern MN
    Also you should probably stock up on O-rings to. I think I had 3 in a row after the 1st one. I remember one being up under the swing circle and leaking lightly down the hose behind that cover and taking awhile to figure out that it wasn't coming from the vicinity of the motor.
    59muskeg likes this.
  9. 59muskeg
    59muskeg Member
    Nov 14, 2016
    21
    Columbus MT
    Thank you
  10. Tones
    Tones Senior Member
    Mar 15, 2009
    1,309
    Ubique
    Yep, under the large hex head.
