Parking for Winter
Discussion in 'Tractor/Loader/Backhoes' started by Katherine A DeHaven, Nov 24, 2022 at 9:11 AM.
  1. Katherine A DeHaven
    Katherine A DeHaven Active Member
    Jul 3, 2022
    34
    12542
    I'm wondering how people park their backhoe for the winter time.
    I don't have a indoor area for my machine. This is the first year I've owned it and I was told to try and park the unit with most of the hydraulic cylinders sheathed.
    Do people utilize blankets to cover up sensitive parts?
    Should I just park it in travel mode or instead how I have it in these photos for the backhoe arm.
    DMiller likes this.
  2. ianjoub
    ianjoub Senior Member
    Jun 22, 2018
    1,040
    Homosassa, FL USA
    spray some oil on the exposed parts of the hydraulic rams to prevent corrosion
    DMiller likes this.
  3. DMiller
    DMiller Senior Member
    Feb 21, 2010
    13,643
    Kinda Retired
    Personally, leave it in Park mode. If do anything with extended cylinders, grease the chromed rams. Grease will deteriorate over time but will not draw moisture. In Travel Locks if does not start or have other issues come spring is easier to reposition for better access to tractor components. Situating the loader arms on home built safety blocks in a semi Up position on the cylinders just in case need to access the engine, fuel filter, starter, is another consideration.
    Billrog and skyking1 like this.
  4. 56wrench
    56wrench Senior Member
    Dec 4, 2016
    1,410
    alberta
    I spray Fluid Film on exposed cyl rods and then wipe it off before next use. Better than oil and not as messy as grease. Also easier to apply:)
    Jonas302, Coaldust, skyking1 and 4 others like this.
  5. JPV
    JPV Senior Member
    Aug 20, 2015
    729
    S.W. Washington
    Fluid film works great.
    Coaldust and DMiller like this.
  6. thepumpguysc
    thepumpguysc Senior Member
    Mar 18, 2010
    6,526
    Master Inj.Pump rebuilder
    Sunny South Carolina
    As stated above..
    Might I add::
    Tarp the engine.
    COVER THE EXHAUST.!!!
    Add some treatment to the fuel and let it circulate into the injection pump and injectors before shutting down..
    Add coolant to radiator and circulate before shutting down.
    56wrench, colson04, Billrog and 2 others like this.
  7. DMiller
    Feb 21, 2010
    13,643
    Kinda Retired
    Had not used Fluid Film, did not realize existed.
  8. hosspuller
    hosspuller Senior Member
    Aug 27, 2014
    1,801
    North Carolina
    While parking the machine for extended times, position the buckets to shed rainwater. Standing water will rust out the bucket bottom.
  9. skyking1
    skyking1 Senior Member
    4,110
    2nd mention on covering the exhaust. If it is really cold and you are not going to start it all winter, then I would be tempted to bring the batteries into the shop and servicing them, and leaving them in the warm. It's a hassle but then there is no drama come spring and batteries that get run down and then charged tend to die a premature death.
  10. Billrog
    Billrog Senior Member
    Mar 26, 2016
    654
    band mill , backhoe and dump truck
    Armstrong, British Columbia
    As given park in trans port position, cover exhaust, I sure wouldn't bother putting anything on the rams I've never seen a rusty one, an option to removing the battery's is either a trickle charger or hook them to a charger every mon. or so to maintain a good charge in them.
    skyking1 and DMiller like this.
  11. skyking1
    4,110
    I like pulling them out every once and a while because corrosion happens. They keep working really well while the battery box is rotting away :)
    DMiller likes this.
  12. NH575E
    NH575E Senior Member
    Dec 30, 2015
    951
    Retired Machinist
    North, FL
    Why would you tarp the engine? I would be more likely to open the covers sos not to create a warm environment for rodents.
    I don't do either with mine but it parks in a open front barn, gets used periodically, and has a cat to protect it.
    Tags and DMiller like this.
  13. skyking1
    4,110
    When it's your plow, and you have it in the barn that's the bomb!
    HarleyHappy and DMiller like this.
  14. Coaldust
    Coaldust Senior Member
    May 9, 2011
    2,132
    North of the 60
    Lots of great advice so far. Another suggestion is to park the tires on wood or masonry, less they sink and freeze in the mud. Maybe that’s not a concern in your location.
    How’s the rodent situation?
    DMiller likes this.
  15. Delmer
    Delmer Senior Member
    Jan 3, 2013
    7,837
    If it's been run regularly and up to date, remove the ground cable from the battery and walk away, if the batteries are dead in the spring then they weren't going to live anyway. Nothing wrong with charging before starting so you don't stress a discharged battery. Even if you're going to charge them every month, or every other month, remove the ground cable. Even a new alternator leaks some current.
    DMiller likes this.
  16. mbavers
    mbavers Well-Known Member
    Oct 11, 2011
    233
    homer alaska
    I've owned my Case 580 SK for about 20 years and bought it used; it's a 1996, I think. It's been outdoors in all weather for all those years (in Alaska). I put it in travel mode (hoe locked upright), place the loader bucket on the ground on edge, close the cab door, and that's it. I never cleaned or oiled the chrome rams and they look like brand new. Also, the chrome on the bumpers of my 1974 Chevy pickup is still clean and shiny, and I never touch it either.
    Tinkerer likes this.
