. Does it load down the engine at all when you switch to a function, like its trying to work? Do the hoses jump at all? Does everything else work fine (that indicates whether the pump is any good).
If you suspect wiring issues, some jumper wires to a battery would be a easy way to check the solenoids/ see what is working and what isn't, much easier than a full wiring harness.
The reason td25c asked about throttle, is because a lot of cranes won't move the outriggers until you throttle it up. They will not move at a idle.
I'm not too concerned about who owns the crane, what I was asking about is if this just started, and how familiar you are with this crane. If you just got it and its been sitting a bunch, and never has worked right, usually that can be a different set of problems, than if you have had the crane for 5 years and everything else works fine, but this just stopped working.
