I got loaded by a Cat 990 one day, needed a ton and a half, dispatcher says go over by the pile and back up to it. Big cat comes around the corner, clips another pile with his bucket and scoops up a few yards in the corner, puts the entire bucket over my truck, F250 and puts a couple yards in the back before I just drove away. bucket was longer than the truck. None on the roof though but looking up at those teeth was somethingYou'd better not care about your cab if you haul on that job.
solder a quarter to a roofing nail and pound it into a step someplace.Reminds me of a Tavern trick-glue a 50 cent piece to the bar top counter.
Up here its needed, some days you can't even get out of the driveway without it.
Besides the Dodge wearing out axle u-joints and front track bars every few years I've never had any issues with increased maintenance on a 4wd pickup from the big 3. Only time things seem to wear out is if I put a suspension lift in.Where there is more parts there will be more maintenance. Two examples.
My f250 has locking hubs, I have a vac leak so I could fix it or just plug the line and go manual, which I did. Last year running down the road I got a huge vibration and ended up being the drive side locking hubs failed and locked it in causing the front driveshaft to turn, and the drive shaft went out on the truck. Now I check the drive shaft every oil change to see if it's free, and I'll lube up my locking hubs probably every other.
I'll link this one to you tube it's so funny. Stupid dodge and their full time locked in front drive shafts, every 100k you should change your front driveshaft. This one went and took out everything. Fuel, shifter, wire harness, transfer case. This is also why I don't trust help, guy wanted a new pickup.
I have 1/2 mile of private road. I had worked on it extensively & was proud how smooth it was. There is 1/10 mile of steep hill. Idiot/friend came up one day: "I spun all the way, but I made it in 2 wheel drive!"We have 150 yards of uphill on our driveway coming in. The pickup empty just chews it up in 2wd so I just slip it into 4wd at the road. Really cut back on driveway maintenance. Cam
I had a 2001 GMC 2500 van converted to 4 wheel drive, (Quigley). It was lifted, as they needed the space between oil pan & differential. It had Dana 44 front axle. I objected, 44 (in my opinion) wasn't heavy enough. They assured me it's rated 4500 LB, it'd be fine. I went through bearings, front brakes, universal joints & steering components endlessly!Besides the Dodge wearing out axle u-joints and front track bars every few years I've never had any issues with increased maintenance on a 4wd pickup from the big 3. Only time things seem to wear out is if I put a suspension lift in.
I was talking to a mechanic buddy he is as old as me. We started working on 4wd long before CV axles and IFS . Out of the blue he started talking about how much things had changed with 4wd.Where's this extra maintenence with a 4wd? Over 200k on the clock and the front end on mine is still as tight as the day it left the factory. Up here its needed, some days you can't even get out of the driveway without it.
