Over Tire tracks
Discussion in 'Skid Steers' started by sandcreek, Apr 29, 2011.
  1. sandcreek
    sandcreek Member
    Apr 26, 2011
    20
    Colorado
    looking at getting a set of steel tracks for S250. Are they hard on tires? Can you get on fairly steep slopes like a rubber tracked machine like a T300?
  2. MaCotMFF
    MaCotMFF Member
    Apr 25, 2011
    9
    Texas Edwards Plateau
    We use tracks over tires on some of our machines. Tires under tracks last a lot longer, especially when in rough, rocky terrain. And yes, the traction is boosted quite a bit.
    A good set of tracks over a set of solid tires is the best combo for low maintenance and longevity.
    My two pence. :D
  3. KSSS
    KSSS Senior Member
    Feb 27, 2005
    3,728
    excavation
    Idaho
    Side hilling with the steel tracks can be hard on the tires with certain tracks. I have the Trail Blazer tracks from Loegren which I think is now called the F track and it has the steel pads. I tore up some tires with these doing a lot of side hilling. I would talk to the track OEM and tell them what you want to do and let them give you the tracks that works the best in that application. As far as climbing, it amazing, better than rubber tracks I think. They are not kind to concrete or asphalt surfaces.
  4. BDFT
    BDFT Senior Member
    Sep 12, 2010
    265
    Northwest BC
    I second everything that's already been said. An S250 on steel tracks will probably run right past a T300 on the sidehill.
  5. lgammon
    lgammon Senior Member
    Mar 26, 2007
    295
    kingsport, tn
    i have a 236 cat with ott tracks and a 277b, the 236 will out preform on a hill but the 277b shines in the sloppy stuff.
  6. sandcreek
    sandcreek Member
    Apr 26, 2011
    20
    Colorado
    Thanks for the help!! I'm surprised that they would out perform a rubber track machine sidehilling
  7. LanceNE
    LanceNE Well-Known Member
    Nov 7, 2009
    101
    Land clearing/Fuels reduction
    Utah
    Had a Cat 262C with over tire Grouser tracks..... on steep hard clay or grassy slopes wanted to slide. It wasn't as stable a platform as our 287 or 297, but was alot (cannot emphasize that enough) lower cost to operate. Plus you have wheels when you need them!
