mitch504
Wow, PH 2.5, I bet your corrosion problems are bad as mine. The problem I've seen with Rhino lining is that if any corrosion gets behind it, it peels off in sheets. How are they prepping the surface?
All the Bobcats that are not white are painted off site. The sunbelt ones go to a few sandblast and paint shops around the area to get the ugly green paint. My brother ran the paint/ powder coating line at the Bobcat plant in gwiinner for 5-6 years. When they are making 150 machines a day its almost impossible to throw in a few odd colored ones.Deere offers special paints to sunbelt rentals but they order anywhere from 300 to 600 backhoes a year and they will do a run of at least 20 at a time
Knowing what I know about factory and all the options in a the build book there are to many options now that get screwed up by the time it gets to the customer
But for what iron costs these days you would think you could get any paint you want
Agressively sandblasting to bare metal with the largest size grit available. It seems to stick reasonably well but the tanks are pulled off every couple of years and re-coated.Wow, PH 2.5, I bet your corrosion problems are bad as mine. The problem I've seen with Rhino lining is that if any corrosion gets behind it, it peels off in sheets. How are they prepping the surface?
Wanna see one close up.?Can see the Glue Like mud hanging off all the machines, Nasty!!
Note how we are above the clouds.
The only thing worse is equipment used around fertilizer, instant rot from day one, brass air fittings are toast in three years. There is no paint that will stand up to it.
Wrenches and sockets don't bother waste of time on bolts-torch them off.
2000ft ASL approx. The "jungle" causes queer weather patterns after it's rained.Elevation?
Total truck life is set at 150,000 hours. That will include a frame refurb at about 80k. Planned component replacement every 18-20k hours based on condition. So planned for seven rebuilds in the total life of the machine. A rebuild comes in at less than half the price of a new truck.ya, I can see why corrosion is a problem Nige. So whats the life expectancy of the loaders and trucks you are assembling now? Do you do a total rebuild once or twice? more?
