Old Hy-Hoe
Discussion in 'Old Iron!' started by Dan83, Sep 30, 2008.
  1. 245dlc
    245dlc Senior Member
    Mar 16, 2010
    1,228
    Heavy Equipment Operator
    Some more pictures of this hybrid beast.
  2. 245dlc
    Mar 16, 2010
    1,228
    And a couple more, I made sure to take lots to see if anybody could identify it for sure.
  3. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    That's pretty typical what it looks like in my area . Somewhat hilly country with narrow roads .
    Almost half of my work is agricultural related in some way or another . So many times we move equipment back these country roads in the middle of nowhere to the job site . I like it .:)
    It's even more fun with Detroit power . ( Big Grin )
    http://s1016.photobucket.com/user/td25c/media/100_2826_zpsd79660df.mp4.html?sort=3&o=29
  4. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    That's a truck mount Hyhoe 245dlc .
    Be interesting to know the story on that rig as it looks like it's mounted on a late 40's / early 50's military truck .
    My 1978 3300 Hyhoe was a military machine originally .
    Not sure when Hyhoe started building machines ? Guessing post WWII years ?
    From what I gather they were the fabricator of the machine and pulled common parts like engine & hydraulics from other manufacturers .
  5. Scrub Puller
    Scrub Puller Senior Member
    Mar 29, 2009
    3,481
    Yair . . . td25c
    What type of pumps do they run mate?
    Cheers.
  6. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
  7. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
  8. Scrub Puller
    Mar 29, 2009
    3,481
    Yair . . .
    Gotcha td25c
    Pretty much as I thought . . . and you can see where my dinosaur thoughts are headed?
    And of course I know 'fuel efficiency' is why the manufacturers have gone to exotic (some say) fragile hydraulics . . . but the fact remains that simple robust machines like yours with basic hydraulics (that even I could troubleshoot and fix) can still pay their way . . . the question I posed up thread was how much difference in the real world does all the complexity and electronics make?
    I might have mentioned an old bloke who had a gravel pit and modified a an 1220 Kato by mounting a lay-on-its side bus engine between the tracks driving a two section pump to run motors off a Linkbelt or something, I know he was running D6
    tracks.
    To reposition he'd swing the house around and access start/stop through a hole in the floor and steer with a couple of removable sticks . . . he never had any more problems with the rotary seal.
    Cheers.
  9. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    Yeah Scrub , The gear pump & motors are pretty simple and bulletproof for the most part . The only draw back I can see is they don't work well at a lower rpm .
    My 3300 HyHoe has a 65 gallon fuel tank . It will run two days on a tank . Probably figure 3 to 4 gallons of fuel per hour depending on throttle setting . That aint bad for a Detroit powered 20 ton Hoe .
  10. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    We finished up this evening on the drainage project .
    Last task was to dig out the front side on an old dam that was leaking a bit though the block wall and had some water running under the footing . We dug it out and lined the bottom & walls with geo cloth & backfilled . My old man worked in the ditch today .:)
  11. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    Moved Hyhoe & skid loader this morning to a small clearing job .
    This is typical chain down for the excavator . So far the 1-1/2 " treated lumber floor on the low boy seems to be holding up . I also lay old conveyer belt down for the tracked equipment to set on .
    Also have pockets welded to the tailboard of the trailer that I drop a 2" pin in to help keep the excavator from sliding sideways off the ramp wile loading .
  12. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    Serviced the machine this morning . Changed oil & installed new belts .
  13. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    Moved in to another patch of small trees customer wanted cleared . About a hour in to the job hydro hose decides to blow on the left side drive motor .:(
    Luckily I had the skid loader & backhoe on site & used it to remove dense undergrowth & dig a shallow trench under the Hyhoe so I could crawl under & wedge myself up in the beast to remove the line at the swing manifold . Drove to town & got a new hose and needed tools . Crow foot wrench worked good for breaking the fitting loose at the manifold .
    Is it Friday yet ..........:).
  14. 1968 Case 580CK
    1968 Case 580CK Senior Member
    Apr 12, 2015
    997
    Virginia
    That was some great backhoe manuevering.....digging the trench up under the belly of the dragon. A roll of duck tape would have saved you the trip to town...ha haa hhaaa.
  15. fixou812
    fixou812 Senior Member
    Dec 17, 2013
    677
    Millwright Equipment Mechanic Welder
    Buffalo NY
    Cool video TD Looks like the old 2 stroke is steaming right along! Careful you don't spill that vodka on the dash!...... " " Carbon Based Vodka Fuled!
  16. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    Why didn't I think of that ? Duct tape is a cure all for problems .
    I was glad to have the skid loader backhoe combo on site to clean out under the old beast . Ground was covered with poison ivy & vines . My concern was while swapping out the hydro hose some rattle headed copper moccasin might crawl up my leg .
  17. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    Thanks fixou812 , My video's are pretty marginal at best .
    LOL! That was my water bottle on the dash when moving the Grove crane . I'm strictly a barley soda drinker .:)
    We moved in to a small patch that customer needed cleared with Hyhoe & skid loader . Trees were maybe ten year growth . Used ditch bucket on excavator to pull trees & skid loader to push & pile when need be .
    http://s1016.photobucket.com/user/td25c/media/100_3239_zpsjkiad0vl.mp4.html
  18. Knepptune
    Knepptune Senior Member
    Nov 22, 2012
    706
    Indiana
    What part of Indiana are you from td. That country sure looks like the VeVay, East Enterprise area. Always like trips through that country. Provided I'm in a car or pickup. Not so much fun in anything big.
  19. mackone
    mackone New Member
    Mar 3, 2016
    2
    truck driver
    kentucky
    72hayes likes this.
  20. 72hayes
    72hayes Well-Known Member
    May 19, 2011
    77
    road builder
    Kelowna B.C.
    Well that is one COOL looking rig!
