Old conventionals at work
Tugger2
British Columbia
She was the Sealion built in 1905 in Vancouver BC. Originally steam and converted to an 8 cylinder Enterprise diesel in the 50 s. She worked towing until 1969 after that became a charter yacht until about 5 years ago when she became derelict.
Her keel was one piece fir 18 X 36 X 120'
It was a bit tough breaking up such a classy old girl but we saved and directed many artifacts into appreciating hands.P1243007.JPG P1263024.JPG
crane operator
sw missouri
Its a testament to the guys that built and maintained that boat from 1905 on. The keel sounds impressive also.
A ship with a tried and true foundation, built by men that knew boats and engines, really exposes the flaws of some of the computer designed gee whiz ships of today.
The US navy is pushing to decommision at minimum 8 of the lcs ships, the oldest of which set sail in 2008, because among other things, it has a gun they can't afford to shoot, and a engine/ transmission combining gear that conks out whenever the captains says "full speed". It would be funny if it wasn't so sad, or expensive.
Glad to see you've been busy.
Tugger2
British Columbia
The best thing about dismantling the Sealion was seeing the care that was put into her maintenance. Every bolt we had to undo had been never seized,no matter where we dug into her. A true testement to men who cared for the boat.And did spend more time undoing things than just ripping and tearing when we could. We came across 1" X 48" silicon bronze bolts holding the engine bed down. As ugly as the work was ,it was an adventure taking her apart.
hvy 1ton
Lawrence, KS
You forgot the galvanic corrosion between the aluminum hull and the steel prop module.
Tugger2
British Columbia
We found no ghosts we were aware of ,but had some interesting visits from a few oldtimers that crewed on the Sealion.
The oddest thing we found in the steel boat was all kinds of steel balls rolling around inside the boxed steel keel.
which one? I have flown into a few in Oregon. I am usually too busy to notice a mill on short final. Sometimes it is nice to be the passenger.
