Oil capacity Cummins 4bt from Onan generator
Discussion in 'Generators/Gensets' started by mattyt1984, May 6, 2022.
  1. mattyt1984
    mattyt1984 Well-Known Member
    Jun 5, 2011
    246
    New York
    Engine didn't come with dip stick or tube. I want to run engine but how much oil does it take 1651857443416184424716448457708.jpg
  2. Birken Vogt
    Birken Vogt Charter Member
    Nov 30, 2003
    4,224
    Grass Valley, Ca
    Why is the dipstick and tube missing? There are spots on both sides, did you check thoroughly? Or is it ripped out somehow?
    Hopefully Cummins can supply you the right ones. Call them with the engine serial number and generator serial number.
    If you need it right now, devising some measuring stick and running 1/2'" to 1" below the oil pan split line ought to get you started until you can get a proper dipstick arranged.
    mg2361 likes this.
  3. mattyt1984
    Jun 5, 2011
    246
    New York
    Really not sure why it is missing but it is. I tried taking one out of another engine but the pans are different. I can use the dip stick and tube but just need to make new marks on stick but need oil capacity for engine
  4. mattyt1984
    Jun 5, 2011
    246
    New York
    Not sure if anyone has manual but engine was out of a Onan 60dgcb.
  5. Nige
    Nige Senior Member
    21,192
    Why not do what Birken suggested.? Take the stick you have and set the Max mark on it 1/2" below the cylinder block/oil pan joint & the Min mark 1" below. Then slowly fill the pan until the oil level reaches the Max mark and measure how much oil you poured in. Simples.
    According to this spec sheet the oil capacity (does not define if it is the complete lubrication system inc filter or just the oil pan) is 11.5 Qt.
    https://csdieselgenerators.com/Images/Generators/2215/Cummins-DGCB-spec-sheet.pdf
    mg2361 likes this.
  6. mattyt1984
    Jun 5, 2011
    246
    New York
    Thanks for info. Now I need to find a starter I'm using a 12 volt starter 13 tooth but it's a 24 volt system. I'm having no luck finding a 24 volt 13 tooth starter. Engine was also missing starter. It's same stater as Dodge truck but I need 24 volt.
  7. Birken Vogt
    Nov 30, 2003
    4,224
    Grass Valley, Ca
    What is your generator serial number? Should be on the rating sticker and start with a single letter followed by 2 digits of the year it was made followed by a bunch of numbers all run together.
  8. mattyt1984
    Jun 5, 2011
    246
    New York
  9. Birken Vogt
    Nov 30, 2003
    4,224
    Grass Valley, Ca
    Try 191-2103 or 391-6854 for the starter, not 100% sure about those, though.
