KENR8916 is for really late (current even) models of D6T, not a 2007 model such as LAY00704.
You need Schematic KENR5131.
I'd also love to know what Codes they came up against.
Changing tack a little (sorry). Somebody help me out here. When you pull an ECM Replacement File using ET for a 3512C HD engine equipped with an ADEM 3 ECM does it contain the Timing Calibration..?
I had a dealer guy telling me the other day that it doesn't. I could have sworn it pulled everything including FLS/FTS settings, injector Trim Codes, etc.
268 is incorrect parameter. Very well could be the ecm failing. Sometimes the internal battery or something fails and they lose the fls/FTS settings and won't record hours on faults. That can set that code.Tech texted me the codes:
268.2
1250-9
He said both of the above are active, and the "service code" staying on is an event code logged. He said that he needed a factory reset password to remove a E198 stored code that is not active but will not clear.
