bpp
The manual for this machine suggests that sediment/water can be drained from the tank, but doesn't give any pictures or instructions. In the front right of the machine, I can see a steel plug pressed into a rubber bushing. I was surprised that the drain plug wasn't a threaded bolt.
If I pull this plug out, is it likely to go back without leaking? Is there a good way to pull this plug without damaging the bushing?
Link to the plug with picture: https://www.bobcatparts.com/hardware/steel-plug-6599645.html
Fuel system diagram (part 5): https://gpim-media.dibhids.net/ipc/pe1192.gif
